编写设备驱动程序
tran_getcap() 入口点
SCSI HBA 驱动程序的 tran_getcap(9E) 入口点通过 scsi_ifgetcap(9F) 进行调用。目标驱动程序调用 scsi_ifgetcap() 可确定 SCSA 定义的一组功能中其中一个的当前值。
目标驱动程序可以通过将 whom 参数设置为非零值来请求特定目标的功能的当前设置。whom 值为零表明请求 SCSI 总线或适配器硬件的一般功能的当前设置。
对于未定义的功能或所请求的功能的当前值,tran_getcap() 入口点应返回 -1
HBA 驱动程序可以使用函数 scsi_hba_lookup_capstr(9F) 来比较功能字符串和已定义功能的标准集。
示例 18–10 HBA 驱动程序 tran_getcap (9E) 入口点
static int
isp_scsi_getcap(
    struct scsi_address    *ap,
    char                   *cap,
    int                    whom)
    struct isp             *isp;
    int                    rval = 0;
    u_char                 tgt = ap->a_target;
    * We don't allow getting capabilities for other targets
    if (cap == NULL || whom  == 0) {
        return (-1);
    isp = (struct isp *)ap->a_hba_tran->tran_hba_private;
    ISP_MUTEX_ENTER(isp);
    switch (scsi_hba_lookup_capstr(cap)) {
    case SCSI_CAP_DMA_MAX:
        rval = 1 << 24; /* Limit to 16MB max transfer */
        break;
    case SCSI_CAP_MSG_OUT:
        rval = 1;
        break;
    case SCSI_CAP_DISCONNECT:
        if ((isp->isp_target_scsi_options[tgt] &
            SCSI_OPTIONS_DR) == 0) {
            break;
        } else if (
            (isp->isp_cap[tgt] & ISP_CAP_DISCONNECT) == 0) {
            break;
        rval = 1;
        break;
    case SCSI_CAP_SYNCHRONOUS:
            SCSI_OPTIONS_SYNC) == 0) {
            break;
        } else if (
            (isp->isp_cap[tgt] & ISP_CAP_SYNC) == 0) {
            break;
        rval = 1;
        break;
    case SCSI_CAP_WIDE_XFER:
            SCSI_OPTIONS_WIDE) == 0) {
            break;
        } else if (
            (isp->isp_cap[tgt] & ISP_CAP_WIDE) == 0) {
            break;
        rval = 1;
        break;
    case SCSI_CAP_TAGGED_QING:
            SCSI_OPTIONS_DR) == 0 ||
            SCSI_OPTIONS_TAG) == 0) {
            break;
        } else if (
            (isp->isp_cap[tgt] & ISP_CAP_TAG) == 0) {
            break;
        rval = 1;
        break;
    case SCSI_CAP_UNTAGGED_QING:
        rval = 1;
        break;
    case SCSI_CAP_PARITY:
        if (isp->isp_target_scsi_options[tgt] &
            SCSI_OPTIONS_PARITY) {
            rval = 1;
        break;
    case SCSI_CAP_INITIATOR_ID:
        rval = isp->isp_initiator_id;
        break;
    case SCSI_CAP_ARQ:
        if (isp->isp_cap[tgt] & ISP_CAP_AUTOSENSE) {
            rval = 1;
        break;
    case SCSI_CAP_LINKED_CMDS:
        break;
    case SCSI_CAP_RESET_NOTIFICATION:
        rval = 1;
        break;
    case SCSI_CAP_GEOMETRY:
        rval = (64 << 16) | 32;
        break;
    default:
        rval = -1;
        break;
    ISP_MUTEX_EXIT(isp);
    return (rval);
