Solaris 10 8/07 Installation Guide: Solaris Flash Archives (Creation and Installation)
Chapter 4 Installing and Administering Solaris Flash Archives (Tasks)
This chapter provides step-by-step procedures for installing a Solaris Flash archive by using the Solaris installation program. This chapter also provides references to procedures for installing Solaris Flash archives when using other installation programs. Also, step-by-step procedures for administering an archive are provided.
Caution – Caution –
When installing the Solaris OS with a Solaris Flash archive, the archive and the installation media must contain identical operating system versions. For example, if the archive is a Solaris 10 operating system and you are using DVD media, then you must use Solaris 10 DVD media to install the archive. If the operating systems versions do not match, the installation on the target system fails.
Installing a Solaris Flash Archive With the Solaris Installation Program
To use the Solaris installation program to install a Solaris Flash archive, use the following procedure.
ProcedureInstalling a Solaris Flash Archive
  1. Begin the Solaris installation program and proceed through the panels until you reach the Specify Media panel. Continue with Solaris Flash installation.
    For the step-by-step procedures, see either of the following procedures.
  2. Specify the media you are using to install.
    1. Type the information that you are prompted to enter.
      Media Selected
      Prompt
      DVD or CD
      Insert the disc where the Solaris Flash archive is located.
      Network File System
      Specify the path to the network file system where the Solaris Flash archive is located. You can also specify the archive file name.
      HTTP
      Specify the URL and proxy information that is needed to access the Solaris Flash archive.
      FTP
      Specify the FTP server and the path to the Solaris Flash archive. Specify the user and password information that allows you access to the FTP server. Specify any proxy information that is needed to access the FTP server.
      Local tape
      Specify the local tape device and the position on the tape where the Solaris Flash archive is located.
      If you selected to install an archive from a DVD, CD, or from an NFS server, the Select Flash Archives panel is displayed.
    2. For archives that are stored on a disc or an NFS server, on the Select Flash Archives panel, select one or more Solaris Flash archives to install.
    3. On the Flash Archives Summary panel, confirm the selected archives and click Next.
    4. On the Additional Flash Archives panel, you can install an additional Solaris Flash archive by specifying the media where the other archive is located. If you do not want to install additional archives, select None.
  3. Click Next to continue the installation.
    Follow the steps from one of the following procedures to complete the installation.
References to Procedures for Installing Solaris Flash Archives
You can use any of the Solaris installation methods to install Solaris Flash archives for an initial installation. You must use custom JumpStart or Solaris Live Upgrade to install a Solaris Flash differential archive.
Type of Installation
Reference
An initial installation to install a Solaris Flash archive
An update with a Solaris Flash differential archive
The flar command enables you to administer archives. You can split an archive into sections. Those sections can be modified, added to, or deleted, and then merged to create an archive. You can also obtain information about the archive.
Caution – Caution –
Do not modify the Archive Files section or you compromise the integrity of the archive.
Splitting a Solaris Flash Archive
You can split an archive into sections, which enables you to modify some sections, add new sections, or delete sections. After you have modified the sections, you need to merge the sections to create an new archive. For example, you might want to add a user-defined section or modify the archive identification section. Do not modify the Archive Files section or you compromise the integrity of the archive.
The flar split command splits a Solaris Flash archive into sections. The flar command copies each section into a separate file in the current directory or specified directory. The files are named after the sections, for example, the archive cookie is saved in a file that is named cookie. You can specify that the flar split command save only one section. The syntax of the command is as follows:
flar split [-d dir] [-u section] [-f archive] [-S section] [-t [-p posn] [-b blocksize]] filename
-d dir
Retrieves the sections to copy from dir, rather than from the current directory.
-u section
  • If you use this option, flar copies the cookie, identification, archive, and section sections. You can specify a single section name or a space-separated list of section names.
  • If you do not use this option, flar copies the cookie, identification, and archive sections only.
-f archive
Extracts the archive section into a directory that is named archive, rather than placing it in a file with the name archive.
-S section
Only copies the section that is named section from the archive. This section is user defined.
Example 4–1 Splitting an Archive
In the following example, archive1.flar is split into three files:
# flar split archive1.flar
After the archive is split, you can modify the archive identification section or add a user-defined section. The sections can then be merged to re-create the archive.
Merging Solaris Flash Archives
After you have split an archive into sections, you can combine the sections to create a new archive.
The flar combine command creates a Solaris Flash archive from individual sections. The following table describes how the flar command handles combining sections.
Conditions
Description
Minimum number of files
Each section is assumed to be in a separate file, the names of which are the section names. These three files must be present:
  • Archive cookie (cookie)
  • Archive identification (identification)
  • Archive files (archive)
Archive copy method
If archive is a directory, the contents are archived before including the directory in the combined archive by using the cpio copy utility.
  • cpio is the default copy method. Individual file sizes cannot be greater than 4 GB.
  • pax is the copy method to handle large individual files. The flarcreate command with the -L pax option uses the pax utility to create an archive without limitations on individual file sizes. Individual file sizes can be greater than 4 GB.
Compressing an archive
If the archive identification section specifies to compress the archive, flar compresses the contents of the newly combined archive.
Validation
No validation is performed on any of the sections. In particular, no fields in the archive identification section are validated or updated.
The following command syntax is for flar combine command.
flar combine [-d dir] [-u section] [-t [-p posn] [-b blocksize]] filename
-d dir
Retrieves the sections to combine from dir, rather than from the current directory.
-u section
Example 4–2 Merging a Solaris Flash Archive
In this example, an archive cookie section, an archive identification section, and an archive files section are combined to become a complete archive. The archive is named newarchive.flar.
# flar combine newarchive.flar
Example 4–3 Merging a Solaris Flash Archive and Adding a User-Defined Section
In this example, an archive cookie section, an archive identification section, an archive files section, and a user-defined section are combined to become a complete archive. The archive is named newarchive.flar. The user-defined section content is in the file that is named user-defined, which is in the current directory.
# flar combine -u user_defined newarchive.flar
Extracting Information From an Archive
Use the flar info command to obtain information about archives you have already created. The syntax of the command is as follows:
flar info [-l] [-k keyword] [-t [-p posn] [-b blocksize]] filename
-k keyword
Returns only the value of the keyword keyword.
-l
Lists all the files in the archive section.
Example 4–4 Listing Files in an Archive Section
In this example, the command checks the file structure of the archive named archive3.flar.
# flar info -l archive3.flar
aaa
aaa/bbb
aaa/bbb/ccc
aaa/bbb/ccc/ddd
aaa/eee
