Solaris 10 5/09 Installation Guide: Solaris Live Upgrade and Upgrade Planning
ProcedureTo Upgrade With a Profile by Using Solaris Live Upgrade
This procedure provides step-by-step instructions for upgrading an OS by using a profile.
If you want to install a Solaris Flash archive by using a profile, see To Install a Solaris Flash Archive With a Profile.
If you added locales to the profile, make sure that you have created a boot environment with additional disk space.
Caution – Caution –
When you install the Solaris OS with a Solaris Flash archive, the archive and the installation media must contain identical OS versions. For example, if the archive is the Solaris 10 operating system and you are using DVD media, then you must use Solaris 10 DVD media to install the archive. If the OS versions do not match, the installation on the target system fails. Identical operating systems are necessary when you use the following keyword or command:
  1. Install the Solaris Live Upgrade SUNWlucfg, SUNWlur, and SUNWluu packages on your system. These packages must be from the release you are upgrading to. For step-by-step procedures, see To Install Solaris Live Upgrade With the pkgadd Command.
  2. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  3. Create a profile.
    See To Create a Profile to be Used by Solaris Live Upgrade for a list of upgrade keywords that can be used in a Solaris Live Upgrade profile.
  4. Type:
    # luupgrade -u -n BE_name -s os_image_path -j profile_path
    Upgrades an operating system image on a boot environment.
    -n BE_name
    Specifies the name of the boot environment that is to be upgraded.
    -s os_image_path
    Specifies the path name of a directory that contains an operating system image. This directory can be on an installation medium, such as a DVD-ROM, CD-ROM, or it can be an NFS or UFS directory.
    -j profile_path
    Path to a profile. The profile must be in a directory on the local machine. For information about creating a profile, see To Create a Profile to be Used by Solaris Live Upgrade.
Example 5–10 Upgrading a Boot Environment by Using a Custom JumpStart Profile
In this example, the second_disk boot environment is upgraded by using a profile. The -j option is used to access the profile. The boot environment is then ready to be activated. To create a profile, see To Create a Profile to be Used by Solaris Live Upgrade. The pkgadd command adds the Solaris Live Upgrade packages from the release you are upgrading to.
# pkgadd -d /server/packages SUNWlucfg SUNWlur SUNWluu
# luupgrade -u -n second_disk \
-s /net/installmachine/export/solarisX/OS_image \
-j /var/tmp/profile
The boot environment is ready to be activated. See Activating a Boot Environment.
