This example shows the migration of an existing resource to a new resource type version. Note that the new resource type package contains only the monitor and RTR file. Because the monitor will be overwritten during installation, the resource must be disabled before the upgraded resource type is installed.
This example assumes the following.
New resource type version is 2.0
Tunability from previous version is “when_unmonitored”
Resource name is “myresource”
Resource type name is “myrt”
New RTR file is in /opt/XYZmyrt/etc/XYZ.myrt
# scswitch -M -n -j myresource (Install the new package according to vendor's directions.) # scrgadm -a -t myrt -f /opt/XYZmyrt/etc/XYZ.myrt # scrgadm -c -j myresource -y Type_version=2.0 # scswitch -M -e -j myresourcee |
