Confirming Server Specifications
Optional Component Installation
Determine Correct Rackmount Hardware
Mark the Rackmounting Location
Install the Rackmount Hardware
Installing and Using the Shipping Bracket Assembly (Optional)
Front Panel Connectors and Ports
Rear Panel Connectors and Ports
Installing and Using the CMA (Optional)
Connect the Ethernet Network Cables
Powering On the Server for the First Time
Oracle ILOM System Console Overview
Connect a Terminal or Emulator to the SER MGT Port
Power On the Server for the First Time
Oracle Solaris OS Configuration Parameters
Assigning a Static IP Address to the Service Processor
Booting the Oracle Solaris Operating System
Understanding System Administration Resources
Platform-Specific Oracle ILOM Features
Oracle VM Server for SPARC Overview
Hardware Management Pack Overview
Source for Downloading Hardware Management Pack Software
Hardware Management Pack Documentation
Display the Oracle ILOM -> Prompt
Reset the Server From the Oracle Solaris OS
Reset the Server From Oracle ILOM
Reset the SP to Default Values
Important Hardware RAID Guidelines
Disk Zones for SPARC T3-1 Servers With Sixteen-Disk Backplanes
Displaying Disk Zone Information
Disk Zone Status (zoningcli list)
Enabling and Disabling Disk Zoning In the Field
Enable Disk Zones (zoningcli Command)
Disable Disk Zones (zoningcli Command)
Update Firmware to Enable Zoning
Minimum System Firmware for Valid devalias in Upper Disk Locations
Prepare to Use the FCode Utility
Hot Spare Drives in RAID Volumes (LSI)
Determining If a Drive Has Failed
Front Service Required Drive LEDs
Error Messages (System Console and Log Files)
Display Status (show-volumes Command, OBP)
Display Status (sas2ircu Utility, LSI)
RAID Drive Replacement Strategies
Changing Server Identification Information
Change Customer FRUdata Information
Change System Identifier Information
Restore Host Power State at Restart
Specify Host Power State at Restart
Disable or Re-Enable Power-On Delay
Specify Parallel Boot of the SP and Host
Configure Host Behavior With the Keyswitch State
Disable or Re-Enable Network Access to the SP
Display the DHCP Server IP Address
Using an In-band Connection to the SP
Configure the Host Boot Mode of Oracle VM Server for SPARC
Change the Host Boot Mode Behavior at Reset
Manage the Host Boot Mode Script
Display Host Boot Mode Expiration Date
Override OpenBoot PROM Settings to Reset the Server
Configuring Server Behavior at Restart
Specify Behavior When the Host Resets
Specify Behavior When the Host Stops Running
Specify Behavior at Boot Timeout
Specify Behavior if Restart Fails
Specify Maximum Restart Attempts
Enabling Automatic System Recovery
Identifying WWN-Designated SAS2 Devices
probe-scsi-all Output Example (SPARC T3-1, Eight-Disk Backplane)
probe-scsi-all Output Example (SPARC T3-1, Sixteen-Disk Backplane)
probe-scsi-all Output Example (SPARC T3-4)
Identify a Disk Slot Using probe-scsi-all (OBP)
Identify a Disk Slot Using prtconf (Oracle Solaris, Onboard Controllers)
Identify a Disk Slot Using prtconf (Oracle Solaris, Single Initiator)
WWN Syntax in an OS Installation on a Specific Device
WWN Syntax in an OS Installation on a RAID Volume
Interpreting Log Files and System Messages
Using Oracle Solaris Predictive Self-Healing
Find the Chassis Serial Number
Understanding Component Replacement Categories
Removing Power From the System
Processor Module Configuration Reference
Replacing a Faulty Processor Module
Install a New Processor Module
Verify Processor Module Functionality
Memory Fault Handling Overview
Understanding DIMM Configurations
Locate a Faulty DIMM Using the DIMM Fault Remind Button
Locate a Faulty DIMM Using the show faulty Command
Increase System Memory With Additional DIMMs
Hard Drive Hot-Pluggable Capabilities
Hard Drive Configuration Reference
Verify Hard Drive Functionality
Power Supply and AC Power Connector Configuration Reference
Power Supply and AC Power Connector LEDs
Verify Power Supply Functionality
Servicing RAID Expansion Modules
Remove the RAID Expansion Module
Install the RAID Expansion Module
Servicing the Service Processor
Locate a Faulty Service Processor
Verify Service Processor Functionality
Fan Module Configuration Reference
Verify Fan Module Functionality
Express Module Configuration Reference
Locate a Faulty Express Module
Verify Express Module Functionality
Locate a Faulty Rear I/O Module
Verify Rear I/O Module Functionality
Servicing the System Configuration PROM
System Configuration PROM Overview
Remove the System Configuration PROM
Install the System Configuration PROM
Servicing the Front I/O Assembly
Install the Front I/O Assembly
Servicing the Storage Backplane
Servicing the Main Module Motherboard
Main Module Motherboard Overview
Locate a Faulty Main Module Motherboard
Remove the Main Module Motherboard
Install the Main Module Motherboard
Verify Main Module Motherboard Functionality
Servicing the Rear Chassis Subassembly
Rear Chassis Subassembly Overview
Remove the Rear Chassis Subassembly
Install the Rear Chassis Subassembly
Connect Power Cords to the Server
Power On the Server (start /SYS Command)
The following probe-scsi-all output examples show the difference in how storage devices are listed when zoning is enabled and when it is disabled. There are 10 disks represented in both examples. They are identified as PhyNum 0-9.
Note - The entries for PhyNum 1-6 are omitted in these examples to reduce the size of the examples. The missing entries would not alter the illustration of the concept.
Zoning is disabled:
When zoning is disabled, each disk is visible to both controllers. The following example shows this by listing every disk with controller 0 and with controller 1.
Tip - Note that SASDeviceName and SASAddress for each PhyNum listed under controller 1 matches the corresponding PhyNum’s DeviceName and SASAddress listed under controller 0. This is true for PhyNum 1-6, which were omitted to reduce the size of the table.
{0} ok probe-scsi-all /pci@400/pci@2/pci@0/pci@f/pci@0/usb@0,2/hub@2/hub@3/storage@2 Unit 0 Removable Read Only device AMI Virtual CDROM 1.00 /pci@400/pci@2/pci@0/pci@4/scsi@0 <==== Controller 1 FCode Version 1.00.56, MPT Version 2.00, Firmware Version 5.00.13.00 Target a Unit 0 Removable Read Only device TEAC DV-W28SS-R 1.0C SATA device PhyNum 6 Target b Unit 0 Disk SEAGATE ST930003SSUN300G 0868 585937500 Blocks, 300 GB SASDeviceName 5000c50017b0c14b SASAddress 5000c50017b0c149 PhyNum 0 [PhyNum 1-6 are omitted to conserve space.] Target 12 Unit 0 Disk SEAGATE ST973402SSUN72G 0400 143374738 Blocks, 73 GB SASDeviceName 5000c50003d5c6a3 SASAddress 5000c50003d5c6a1 PhyNum 7 Target 13 Unit 0 Disk SEAGATE ST914603SSUN146G 0768 286739329 Blocks, 146 GB SASDeviceName 5000c50012ef2247 SASAddress 5000c50012ef2245 PhyNum 8 Target 14 Unit 0 Disk SEAGATE ST973402SSUN72G 0400 143374738 Blocks, 73 GB SASDeviceName 5000c50003d49c77 SASAddress 5000c50003d49c75 PhyNum 9 Target 15 Unit 0 Encl Serv device SUN SAS2 X16DBP 0302 SASAddress 500605b0000272bd PhyNum 18 /pci@400/pci@1/pci@0/pci@4/scsi@0 <==== Controller 0 FCode Version 1.00.56, MPT Version 2.00, Firmware Version 5.00.13.00 Target a Unit 0 Disk SEAGATE ST930003SSUN300G 0868 585937500 Blocks, 300 GB SASDeviceName 5000c50017b0c14b SASAddress 5000c50017b0c149 PhyNum 0 [PhyNum 1-6 are omitted to conserve space.] Target 11 Unit 0 Disk SEAGATE ST973402SSUN72G 0400 143374738 Blocks, 73 GB SASDeviceName 5000c50003d5c6a3 SASAddress 5000c50003d5c6a1 PhyNum 7 Target 12 Unit 0 Disk SEAGATE ST914603SSUN146G 0768 286739329 Blocks, 146 GB SASDeviceName 5000c50012ef2247 SASAddress 5000c50012ef2245 PhyNum 8 Target 13 Unit 0 Disk SEAGATE ST973402SSUN72G 0400 143374738 Blocks, 73 GB SASDeviceName 5000c50003d49c77 SASAddress 5000c50003d49c75 PhyNum 9 Target 14 Unit 0 Encl Serv device SUN SAS2 X16DBP 0302 SASAddress 500605b0000272bd PhyNum 18 {0} ok
Zoning is enabled:
In the following example, zoning is enabled and each disk is shown connected to a single SAS-2 controller. PhyNum 0-7 are connected to controller 0 and PhyNum 8-9 are connected to controller 1.
{0} ok probe-scsi-all /pci@400/pci@2/pci@0/pci@f/pci@0/usb@0,2/hub@2/hub@3/storage@2 Unit 0 Removable Read Only device AMI Virtual CDROM 1.00 /pci@400/pci@2/pci@0/pci@4/scsi@0 <==== Controller 1 FCode Version 1.00.56, MPT Version 2.00, Firmware Version 5.00.13.00 Target a Unit 0 Disk SEAGATE ST914603SSUN146G 0768 286739329 Blocks, 146 GB SASDeviceName 5000c50012ef2247 SASAddress 5000c50012ef2245 PhyNum 8 Target b Unit 0 Disk SEAGATE ST973402SSUN72G 0400 143374738 Blocks, 73 GB SASDeviceName 5000c50003d49c77 SASAddress 5000c50003d49c75 PhyNum 9 Target c Unit 0 Encl Serv device SUN SAS2 X16DBP 0305 SASAddress 50800200000272bd PhyNum 18 Target d Unit 0 Removable Read Only device TEAC DV-W28SS-R 1.0C SATA device PhyNum 6 /pci@400/pci@1/pci@0/pci@4/scsi@0 <==== Controller 0 Target a Unit 0 Disk SEAGATE ST930003SSUN300G 0868 585937500 Blocks, 300 GB SASDeviceName 5000c50017b0c14b SASAddress 5000c50017b0c149 PhyNum 0 [PhyNum 1-6 are omitted to conserve space.] Target 11 Unit 0 Disk SEAGATE ST973402SSUN72G 0400 143374738 Blocks, 73 GB SASDeviceName 5000c50003d5c6a3 SASAddress 5000c50003d5c6a1 PhyNum 7 Target 12 Unit 0 Encl Serv device SUN SAS2 X16DBP 0305 SASAddress 50800200000272bd PhyNum 18 {0} ok
