This section describes what data to collect when you cannot login to Directory Editor.
Take a screen shot of the login screen.
The screen shot should show the error message that results when you try to login.
Note the result of an attempt to login to Directory Editor as cn=Directory Manager.
The cn=Directory Manager user might be able to login although other users cannot.
Collect the user-prob.ldif file generated by the ldapsearch command.
server-root/shared/bin/ldapsearch -h hostname -p port -D "cn=Directory Manager" -w password -b "base-dn" "(uid=userID)" > /tmp/user-prob.ldif
server-root\shared\bin\ldapsearch.exe -h hostname -p port -D "cn=Directory Manager" -w password -b "base-dn" "(uid=userID)" > C:\user-prob.ldif
Here, base-dn means the DN of the suffix used in your environment to store user entries, such as ou=people,dc=example,dc=com.
Collect the error logs for your application server.
For example, if you run Directory Editor in the first domain and instance of Sun Java System Application Server, collect app-server-root/domains/domain1/server1/logs/server.log.
Collect logs from both the Directory Editor Configuration Directory Server and also Managed Directory Servers.
By default, you find these logs in the following locations:
server-root/slapd-serverID/logs/access
server-root/slapd-serverID/logs/errors
server-root/slapd-serverID/logs/audit (if enabled)
If these log files are not in the default locations, examine the Directory Server configuration file, server-root/slapd-serverID/config/dse.ldif, to find the paths to the logs. The paths are specified as the values of attributes nsslapd-accesslog, nsslapd-errorlog, and nsslapd-auditlog.
Collect the de-login-problem-services.ldif file generated by the ldapsearch command for both the Configuration Directory Server and the Managed Directory Servers.
Be sure to include the -B option, which retrieves binary attribute values as they are stored in the directory.
server-root/shared/bin/ldapsearch -h hostname -p port -D "cn=Directory Manager" -w password -B -b "ou=1.0,ou=DML,ou=services,dc-root" "(objectclass=*)" > /tmp/de-login-problem-services.ldif
server-root\shared\bin\ldapsearch.exe -h hostname -p port -D "cn=Directory Manager" -w password -B -b "ou=1.0,ou=DML,ou=services,dc-root" "(objectclass=*)" > C:\de-login-problem-services.ldif
Here, dc-root means the domain controller suffix for the configuration directory used in your environment, such as dc=example,dc=com.
Collect the de-login-problem-aci.ldif file generated by the ldapsearch command for the Managed Directory Servers.
server-root/shared/bin/ldapsearch -h hostname -p port -D "cn=Directory Manager" -w password -b "base-dn" "(objectclass=*)" aci > /tmp/de-login-problem-aci.ldif
server-root\shared\bin\ldapsearch.exe -h hostname -p port -D "cn=Directory Manager" -w password -b "base-dn" "(objectclass=*)" aci > C:\de-login-problem-aci.ldif
Collect trace logging information showing authentication activity.
To collect this information, perform the following steps.
Open the app-server-root/WEB-INF/classes/log4j.properties file in a text editor.
Add the following lines.
log4j.logger.com.sun.dml.auth=TRACE,auth log4j.appender.auth=org.apache.log4j.RollingFileAppender log4j.appender.auth.layout=org.apache.log4j.PatternLayout log4j.appender.auth.layout.ConversionPattern=%d{ISO8601} [%t] %-5p %c - %m%n log4j.appender.auth.File=de-auth.log log4j.appender.auth.MaxFileSize=5MB log4j.appender.auth.MaxBackupIndex=1
Restart Directory Editor.
Reproduce the login problem immediately.
Collect the log file or files named de-auth.log.
