This section describes what data to collect when you cannot start Directory Editor.
Collect information about the port used for your application server.
netstat -an | grep app-server-port
netstat -an
Collect error logs for your application server.
For example, if you run Directory Editor in the first domain and instance of Sun Java System Application Server, collect app-server-root/domains/domain1/server1/logs/server.log.
Collect logs from both the Directory Editor Configuration Directory Server and also Managed Directory Servers.
By default, you find these logs in the following locations:
server-root/slapd-serverID/logs/access
server-root/slapd-serverID/logs/errors
server-root/slapd-serverID/logs/audit (if enabled)
If these log files are not in the default locations, examine the Directory Server configuration file, server-root/slapd-/serverID/config/dse.ldif, to find the paths to the logs. The paths are specified as the values of attributes nsslapd-accesslog, nsslapd-errorlog, and nsslapd-auditlog.
Collect the de-startup-problem-services.ldif file generated by the ldapsearch command.
Be sure to include the -B option, which retrieves binary attribute values as they are stored in the directory.
server-root/shared/bin/ldapsearch -h hostname -p port -D "cn=Directory Manager" -w password -B -b "ou=1.0,ou=DML,ou=services,dc-root" "(objectclass=*)" > /tmp/de-startup-problem-services.ldif
server-root\shared\bin\ldapsearch.exe -h hostname -p port -D "cn=Directory Manager" -w password -B -b "ou=1.0,ou=DML,ou=services,dc-root" "(objectclass=*)" > C:\de-startup-problem-services.ldif
Here, dc-root means the domain controller suffix for the configuration directory used in your environment, such as dc=example,dc=com.
