Loading the Initial Data Set for a Sun Master Index
Loading Matched Data Using SQL*Loader
Note –
This procedure includes steps that were updated for Java CAPS Release 6 Update 1. The variable JDBC_JAR_PATH was previously ORACLE_JDBC_JAR, and wasn't present in all files.
If the master index database runs on an Oracle platform, you can use either SQL*Loader or the Data Integrator Bulk Loader to load the matched data into the database. SQL*Loader cannot be used for a SQL Server or MySQL database.
ProcedureTo Load Matched Data Using SQL*Loader
  1. Complete the steps under Performing the Bulk Match.
  2. From the master IBML Tool home directory, run cluster-truncate.sql against the cluster synchronizer database.
  3. For each IBML Tool, open loader-config.xml (located in the IBML Tool home directory in the conf subdirectory).
    1. Define the SQL*Loader property as described in SQL*Loader Configuration.
    2. Change the value of the BulkLoad property to true.
    3. Save and close the file.
  4. To generate the loader, do one of the following.
    • If the master loader is running on Windows:
      1. Navigate to the master IBML Tool home directory and open generate-sql-loader.bat for editing.
      2. Change the value of the JDBC_JAR_PATH variable in the first line to the location and name of the database driver for the master index database platform; for example, set JDBC_JAR_PATH=C:\oracle\jdbc\lib\ojdbc14.jar.
      3. Close and save the file.
      4. Double-click generate-sql-loader.bat or type generate-sql-loader from a command line.
    • If the master loader is running on UNIX:
      1. Navigate to the master IBML Tool home directory and open sh generate-sql-loader.sh for editing.
      2. Change the value of the JDBC_JAR_PATH variable in the first line to the location and name of the database driver for the master index database platform; for example, export JDBC_JAR_PATH=${oracle_home}/jdbc/lib/ojdbc14.jar.
      4. Type sh generate-sql-loader.sh at the command line.
      A new directory named sqlldr is created in the working directory.
  5. In the master IBML Tool home directory, run cluster-truncate.sql against the master index database to clear the cluster synchronizer tables.
  6. In the sqlldr folder in the working directory, run drop.sql against the master index database to drop constraints and indexes.
  7. In the sqlldr directory, do one of the following:
    • On Windows, double-click bulk-loader.bat or type bulk-loader.bat from a command line.
    • On UNIX, type sh bulk-loader.sh at the command line.
  8. After the data is loaded, close any command prompts that were left open by the process and examine the SQL*Loader log files located in the sqlldr/log directory to ensure there were no errors during processing.
    Note –
    Any records that contained bad data and were not inserted into the master index database are written to the sqlldr/bad directory. Any records that contained bad data and were discarded are written to the sqlldr/discard directory.
  9. In the sqlldr directory, run create.sql against the master index database to reinstate the dropped indexes and constraints.
