If you create your own Decision Maker class, you can specify the new class to be used by changing the value of the decision-maker-class element.
In the Projects window, expand the Configuration node in the project you want to modify, and then double-click master.xml.
Scroll to the DecisionMakerConfig element.
Change the value of the decision-maker-class element to the path and name of the new Decision Maker class.
For example:
<decision-maker-class>com.sun.mdm.index.decision.impl.MyDecisionMaker </decision-maker-class> |
Save and close the file.
