SunSHIELD Basic Security Module Guide
User-Level Generated Audit Records
These audit records are created by applications that operate outside the kernel. The records are sorted alphabetically by program. The description of each record includes:
Table A-160 allocate-device success
Event Name
Program
Event ID
Event Class
Mask
AUE_allocate_succ
/usr/sbin/allocate
6200
ad
0x00000800
Format:
header-token
text-token
path-token
subject-token
exit-token
Table A-161 allocate-device failure
Event Name
Program
Event ID
Event Class
Mask
AUE_allocate_fail
/usr/sbin/allocate
6201
ad
0x00000800
Format:
header-token
text-token
subject-token
exit-token
Table A-162 deallocate-device success
Event Name
Program
Event ID
Event Class
Mask
AUE_deallocate_succ
/usr/sbin/deallocate
6202
ad
0x00000800
Format:
header-token
subject-token
newgroups-token
exit-token
Table A-163 deallocate-device failure
Event Name
Program
Event ID
Event Class
Mask
AUE_deallocate_fail
6203
ad
0x00000800
Format:
header-token
subject-token
newgroups-token
exit-token
Table A-164 allocate-list devices success
Event Name
Program
Event ID
Event Class
Mask
AUE_listdevice_succ
/usr/sbin/allocate
6205
ad
0x00000800
Format:
header-token
subject-token
[group-token]
exit-token
Table A-165 allocate-list devices failure
Event Name
Program
Event ID
Event Class
Mask
AUE_listdevice_fail
/usr/sbin/allocate
6206
ad
0x00000800
Format:
header-token
subject-token
 [group-token]
exit-token
Table A-166 at-create crontab
Event Name
Program
Event ID
Event Class
Mask
AUE_at_create
/usr/bin/at
6144
ad
0x00000800
Format:
header-token
subject-token
[group-token]
exit-token
Table A-167 at-delete atjob (at or atrm)
Event Name
Program
Event ID
Event Class
Mask
AUE_at_delete
/usr/bin/at
6145
ad
0x00000800
Format:
header-token
subject-token
[group-token]
exit-token
Table A-168 at-permission
Event Name
Program
Event ID
Event Class
Mask
AUE_at_perm
/usr/bin/at
6146
ad
0x00000800
Format:
header-token
subject-token
[group-token]
exit-token
Table A-169 crontab-crontab created
Event Name
Program
Event ID
Event Class
Mask
AUE_crontab_create
/usr/bin/crontab
6148
ad
0x00000800
Format:
header-token
subject-token
[group-token]
exit-token
Table A-170 crontab-crontab deleted
Event Name
Program
Event ID
Event Class
Mask
AUE_crontab_delete
/usr/bin/crontab
6149
ad
0x00000800
Format:
header-token
subject-token
[group-token]
exit-token
Table A-171 cron-invoke atjob or crontab
Event Name
Program
Event ID
Event Class
Mask
AUE_cron_invoke
/usr/bin/crontab
6147
ad
0x00000800
Format:
header-token
subject-token
text-token      (program)
text-token      (shell)
text-token      (cmd)
exit-token
Table A-172 crontab-permission
Event Name
Program
Event ID
Event Class
Mask
AUE_crontab_perm
/usr/bin/crontab
6150
ad
0x00000800
Format:
header-token
subject-token
[group-token]
exit-token
Table A-173 halt(1m)
Event Name
Program
Event ID
Event Class
Mask
AUE_halt_solaris
/usr/sbin/halt
6160
ad
0x00000800
Format:
header-token
subject-token
return-token
Table A-174 inetd
Event Name
Program
Event ID
Event Class
Mask
AUE_inetd_connect
/usr/sbin/inetd
6151
na
0x00000400
Format:
header-token
subject-token
text-token      (service name)
in_addr-token
iport-token
return-token
Table A-175 init(1m)
Event Name
Program
Event ID
Event Class
Mask
AUE_init_solaris
/sbin/init; /usr/sbin/init; /usr/sbin/shutdown
6166
ad
0x00000800
Format:
header-token
subject-token
text-token      (init level)
return-token
Table A-176 ftp access
Event Name
Program
Event ID
Event Class
Mask
AUE_ftpd
/usr/sbin/in.ftpd
6165
lo
0x00001000
Format:
header-token
subject-token
text-token      (error message, failure only)
return-token
Table A-177 login - local
Event Name
Program
Event ID
Event Class
Mask
AUE_login
/usr/sbin/login
6152
lo
0x00001000
Format:
header-token
subject-token
text-token      (error message)
return-token
Table A-178 login - rlogin
Event Name
Program
Event ID
Event Class
Mask
AUE_rlogin
/usr/sbin/login
6155
lo
0x00001000
Format:
header-token
subject-token
return-token
Table A-179 login - telnet
Event Name
Program
Event ID
Event Class
Mask
AUE_telnet
/usr/sbin/login
6154
lo
0x00001000
Format:
header-token
subject-token
return-token
Table A-180 logout
Event Name
Program
Event ID
Event Class
Mask
AUE_logout
/usr/sbin/login
6153
lo
0x00001000
Format:
header-token
subject-token
text-token
return-token
Table A-181 mount
Event Name
Program
Event ID
Event Class
Mask
AUE_mountd_mount
/usr/lib/nfs/mountd
6156
na
0x00000400
Format:
header-token
arg-token
text-token      (remote client hostname)
path-token     (mount dir)
attribute-token
path-token
attribute-token
subject-token
return-token
Table A-182 unmount
Event Name
Program
Event ID
Event Class
Mask
AUE_mountd_umount
/usr/lib/nfs/mountd
6157
na
0x00000400
Format:
header-token
attribute-token
subject-token
return-token
Table A-183 passwd
Event Name
Program
Event ID
Event Class
Mask
AUE_passwd
/usr/bin/passwd
6163
lo
0x00001000
Format:
header-token
subject-token
return-token
Table A-184 poweroff(1m)
Event Name
Program
Event ID
Event Class
Mask
AUE_poweroff_solaris
/usr/sbin/poweroff
6169
ad
0x00000800
Format:
header-token
subject-token
return-token
Table A-185 reboot(1m)
Event Name
Program
Event ID
Event Class
Mask
AUE_reboot_solaris
/usr/sbin/reboot
6161
ad
0x00000800
Format:
header-token
subject-token
return-token
Table A-186 rexd
Event Name
Program
Event ID
Event Class
Mask
AUE_rexd
/usr/sbin/rpc.rexd
6164
lo
0x00001000
Format:
header-token
subject-token
text-token      (hostname)
text-token      (username)
text-token      (command to be executed)
exit-token
Table A-187 rexecd
Event Name
Program
Event ID
Event Class
Mask
AUE_rexecd
/usr/sbin/in.rexecd
6162
lo
0x00001000
Format:
header-token
subject-token
exit-token
Table A-188 rsh access
Event Name
Program
Event ID
Event Class
Mask
AUE_rshd
/usr/sbin/in.rshd
6158
lo
0x00001000
Format:
header-token
subject-token
text-token      (command string)
text-token      (local user)
text-token      (remote user)
return-token
Table A-189 shutdown(1b)
Event Name
Program
Event ID
Event Class
Mask
AUE_shutdown_solaris
/usr/ucb/shutdown
6168
ad
0x00000800
Format:
header-token
subject-token
return-token
Table A-190 su
Event Name
Program
Event ID
Event Class
Mask
AUE_su
/usr/bin/su
6159
lo
0x00001000
Format:
header-token
subject-token
return-token
Table A-191 admin(1m)
Event Name
Program
Event ID
Event Class
Mask
AUE_uadmin_solaris
/sbin/uadmin; /usr/sbin/uadmin
6167
ad
0x00000800
Format:
header-token
subject-token
text-token      (function)
text-token      (argument)
return-token
