SunSHIELD Basic Security Module Guide
process Token
The process token contains information describing a process as an object such as the recipient of a signal. The token has 9 fields: a token ID that identifies this token as a process token, the invariant audit ID, the effective user ID, the effective group ID, the real user ID, the real group ID, the process ID, the audit session ID, and a terminal ID. Figure A-20 shows a process token.
Figure A-20 process Token Format
Graphic
The audit ID, user ID, group ID, process ID, and session ID are long instead of short.
Note -
The process token fields for the session ID, the real user ID, or the real group ID might be unavailable. The entry is then set to -1.
