Writing Device Drivers
/etc/system
The /etc/system file is read once while the kernel is booting. It is used to set various kernel options. After this file is modified, the system must be rebooted for the changes to take effect. If a change in the file causes the system not to work, boot with the ask (-a) option and specify /dev/null as the system file.
Add the following set commands to the /etc/system file:
See system(4) for more information.
Note -
Most kernel variables are not guaranteed to be present in subsequent releases.
