moddebug is a kernel variable that controls the module loading process. The possible values are:
0x80000000 |
Prints messages to the console when loading or unloading modules. |
0x40000000 |
Gives more detailed error messages. |
0x20000000 |
Prints more detail when loading or unloading (such as including the address and size). |
0x00001000 |
No autounloading drivers: the system will not attempt to unload the device driver when the system resources become low. |
0x00000080 |
No autounloading streams: the system will not attempt to unload the streams module when the system resources become low. |
0x00000010 |
No autounloading of drivers of any type. Module loading is disabled. |
0x00000004 |
Not acceptable to page out symbol table. Prevents kernel from (possibly) paging out the driver's symbol table. kadb requires access to the symbol table to operate properly. |
0x00000001 |
If running with kadb, moddebug causes a breakpoint to be executed and a return to kadb immediately before each module's _init(9E) routine is called. Also generates additional debug messages when the module's _info and _fini routines are executed. |
