The tran_sync_pkt(9E) entry point is the HBA driver function that synchronizes the DMA object allocated for the scsi_pkt(9S) structure before or after a DMA transfer. The tran_sync_pkt(9E) entry point is called when the target driver calls scsi_sync_pkt(9F).
If the data transfer direction is a DMA read from device to memory, tran_sync_pkt(9E) must synchronize the CPU's view of the data. If the data transfer direction is a DMA write from memory to device, tran_sync_pkt(9E) must synchronize the device's view of the data.
static void isp_scsi_sync_pkt( struct scsi_address *ap, struct scsi_pkt *pkt) { struct isp_cmd *sp = (struct isp_cmd *)pkt->pkt_ha_private; if (sp->cmd_flags & CFLAG_DMAVALID) { (void)ddi_dma_sync(sp->cmd_dmahandle, sp->cmd_dma_offset, sp->cmd_dma_len, (sp->cmd_flags & CFLAG_DMASEND) ? DDI_DMA_SYNC_FORDEV : DDI_DMA_SYNC_FORCPU); } } }
