Use the Appointment Editor to create an appointment but don't click Insert.
In an open File Manager window, navigate to a folder where you want to save the appointment in a file.
With both the File Manager window and Calendar Appointment Editor visible on your screen, drag the Drag Appt icon from the Appointment Editor and drop it on the File Manager window.
The appointment is saved in a text file in the folder where you dropped it.
For more information about File Manager, see Chapter 5, Managing Files with File Manager .
