Choose Options from the File menu.
Choose Access List and Permissions from the Category menu.
Select the user to whom you want to deny access in the Access list.
Click Remove Name (Calendar data version 3, Figure 11-1) or Delete (Calendar data version 4, Figure 11-2) to remove the user from the Access list.
To remove access for the specified user and close the dialog box, click OK.
To remove access for the specified users and leave the dialog box displayed, click Apply.
To erase your changes and leave the dialog box displayed, click Reset.
To erase your changes and close the dialog box, click Cancel.
