Use sdtcm_admin from the command line to create and administer calendars. This tool can be used to add or remove a calendar on a local system or remotely on a host on the network. Use sdtcm_admin to list calendars that exist on a host, or to grant and revoke access to users to a specific calendar. Options to sdtcm_admin include:
-l |
Lists calendars on your system in a single column |
-h |
Lists calendars on other hosts |
-a |
Adds a new calendar to a system (by default, login@localhost) |
-c |
Add a named calendar to a system |
-d |
Delete a calendar from a system (by default, removes) |
See the sdtcm_admin(1) man page for more details and examples of the other options.
To list calendars on your system:
% sdtcm_admin -l
kasso
vacation
test
foobar
sleepy
To list calendars on another host:
% sdtcm_admin -l -h totoro
ytso
root
test
sportv4
To add a calendar with your login name to the host you are logged in to:
% sdtcm_admin -a
By default the -a option will create the calendar <login>@<localhost>. Other calendars can be created on the host by using the -c option.
To create the calendar buildschedule on the local host, aha:
% sdtcm_admin -a -c buildschedule@aha
To create the calendar sleepy on the remote host totoro:
% sdtcm_admin -a -c sleepy@totoro
To remove the calendar with your login name from the host you are logged in to:
% sdtcm_admin -d
By default the -d option will remove the calendar <login>@<localhost>. For example, if kasso is logged into aha and runs sdtcm_admin -d with no other options, the following response will be displayed:
Delete the calendar kasso@aha [y/n]?
Respond y or n.
To remove the calendar old on the host aha:
% sdtcm_admin -d -c old@aha
You can only remove calendars for which you have Owner privileges. If you attempt to remove a calendar that you do not own, you will see an error message:
Delete the calendar old@aha [y/n]? y
sdtcm_admin: Could not delete calendar because: Permission denied.
