Solaris Common Desktop Environment: User's Guide
To Copy Files or Folders to a Diskette
  1. Select the icon for the file or folder you want to copy.
  2. Choose Copy to from the Selected menu.
    The Copy Object dialog box appears.
  3. Type a full path name in the Destination Folder text field.
    Use /floppy as the directory name. For example, if you want to copy the file report onto a diskette named john, you would type /floppy/john.
  4. Type the file or folder name in the Name for copy text field.
    In the above example, you would type report.
  5. Click OK or press Return.
    Note -
    You cannot copy files or folders to a CD-ROM.
