You can get a pkginfo display in any of three formats: short, extracted, and long.
The short format is the default. It shows only the category, package abbreviation, and full package name, as shown in "The Default pkginfo Display".
The extracted format shows the package abbreviation, package name, package architecture (if available), and package version (if available). Use the -x option to request the extracted format as shown in the next example.
$ pkginfo -x . . . SUNWipc Interprocess Communications (sparc) 11.5.1,REV=95.10.27.15.23 SUNWisolc XSH4 conversion for ISO Latin character sets (sparc) 1.0,REV=5.0 SUNWkcspf KCMS Optional Profiles (sparc) 1.0,REV=1.0.14 SUNWkcspg KCMS Programmers Environment (sparc) 1.0,REV=1.0.1 . . . $ |
Using the -l option produces a display in the long format showing all of the available information about a package, as in the following example.
$ pkginfo -l SUNWcadap PKGINST: SUNWcadap NAME: Chip designers need CAD application software to design abc chips. Runs only on xyz hardware and is installed in the usr partition. CATEGORY: system ARCH: SPARC VERSION: release 1.0 BASEDIR: /opt PSTAMP: system980706083849 INSTDATE: Jul 7 1998 09:58 STATUS: completely installed FILES: 13 installed pathnames 6 directories 3 executables 3121 blocks used (approx) $ |
