PKG=ncmp NAME=NCMP Utilities CATEGORY=application, tools BASEDIR=/ ARCH=SPARC VERSION=RELEASE 1.0, Issue 1.0 CLASSES="" NCMPBIN=/bin NCMPMAN=/usr/man EMACS=/usr/emacs |
i pkginfo i request x bin $NCMPBIN 0755 root other f bin $NCMPBIN/dired=/usr/ncmp/bin/dired 0755 root other f bin $NCMPBIN/less=/usr/ncmp/bin/less 0755 root other f bin $NCMPBIN/ttype=/usr/ncmp/bin/ttype 0755 root other f emacs $NCMPBIN/emacs=/usr/ncmp/bin/emacs 0755 root other x emacs $EMACS 0755 root other f emacs $EMACS/ansii=/usr/ncmp/lib/emacs/macros/ansii 0644 root other f emacs $EMACS/box=/usr/ncmp/lib/emacs/macros/box 0644 root other f emacs $EMACS/crypt=/usr/ncmp/lib/emacs/macros/crypt 0644 root other f emacs $EMACS/draw=/usr/ncmp/lib/emacs/macros/draw 0644 root other f emacs $EMACS/mail=/usr/ncmp/lib/emacs/macros/mail 0644 root other f emacs $NCMPMAN/man1/emacs.1=/usr/ncmp/man/man1/emacs.1 0644 root other d man $NCMPMAN 0755 root other d man $NCMPMAN/man1 0755 root other f man $NCMPMAN/man1/dired.1=/usr/ncmp/man/man1/dired.1 0644 root other f man $NCMPMAN/man1/ttype.1=/usr/ncmp/man/man1/ttype.1 0644 root other f man $NCMPMAN/man1/less.1=/usr/ncmp/man/man1/less.1 0644 inixmr other |
Note that a request script can exit without leaving any files on the file system. For installations on Solaris versions prior to 2.5 and compatible versions (where no checkinstall script may be used) the request script is the correct place to test the file system in any manner necessary to ensure that the installation will succeed. When the request script exits with code 1, the installation will quit cleanly.
These example files show the use of parametric paths to establish multiple base directories. However, the preferred method involves use of the BASEDIR
parameter which is managed and validated by the pkgadd command. Whenever multiple base directories are used, take special care to provide for installation of multiple versions and architectures on the same platform.
