To set up the selective installation in this case study, you must complete the following tasks:
Define a class for each type of object that can be installed.
In this case study, the three object types are the package executables, the man pages, and the emacs executables. Each type has its own class: bin, man, and emacs, respectively. Notice that in the prototype file all the object files belong to one of these three classes.
Initialize the CLASSES
parameter in the pkginfo file to null.
Normally when you define a class, you should list that class in the CLASSES
parameter in the pkginfo file. Otherwise, no objects in that class are installed. For this case study, the parameter is initially set to null, which means no objects will get installed. The CLASSES
parameter will be changed by the request script, based on the choices of the administrator. This way, the CLASSES
parameter is set to only those object types that the administrator wants installed.
Usually it is a good idea to set parameters to a default value. If this package had components common to all three object types, you could assign them to the none class, and then set the CLASSES
parameter equal to none.
Insert parametric path names into the prototype file.
The request script sets these environment variables to the value that the administrator provides. Then, the pkgadd command resolves these environment variables at installation time and knows where to install the package.
The three environment variables used in this example are set to their default in the pkginfo file and serve the following purposes:
$NCMPBIN defines the location for object executables
$NCMPMAN defines the location for man pages
$EMACS defines the location for emacs executables
The example prototype file shows how to define the object path names with variables.
Create a request script to ask the administrator which parts of the package should be installed and where they should be placed.
The request script for this package asks the administrator two questions:
Should this part of the package be installed?
When the answer is yes, the appropriate class name is added to the CLASSES
parameter. For example, when the administrator chooses to install the man pages associated with this package, the class man is added to the CLASSES
parameter.
If so, where should this part of the package be placed?
The appropriate environment variable is set to the response to this question. In the man page example, the variable $NCMPMAN is set to the response value.
These two questions are repeated for each of the three object types.
At the end of the request script, the parameters are made available to the installation environment for the pkgadd command and any other packaging scripts. The request script does this by writing these definitions to the file provided by the calling utility. For this case study, no other scripts are provided.
When looking at the request script for this case study, notice that the questions are generated by the data validation tools ckyorn and ckpath. For more information on these tools see the ckyorn(1) and ckpath(1) man pages.
