STREAMS Programming Guide
Using qband(9S) Information
The STREAMS utility routines should be used when manipulating the fields in the queue and qband structures. strqget(9F) and strqset(9F) are used to access band information.
Drivers and modules can change the qb_hiwat and qb_lowat fields of the qband structure. Drivers and modules can only read the qb_count, qb_first, qb_last, and qb_flag fields of the qband structure. Only the fields listed previously can be referenced. There are fields in the structure that are reserved and are not documented.
Figure 7-11 shows a queue with two extra bands of flow.
Figure 7-11 Data Structure Linkage
Several routines are provided to aid you in controlling each priority band of data flow. These routines are
flushband(9F) is discussed in "Flush Handling". bcanputnext(9F) is discussed in "Flow Control in Service Procedures", and the other two routines are described in the following section. Appendix B, STREAMS Utilities also has a description of these routines.
