Common Desktop Environment: Help System Author's and Programmer's Guide
To Provide a Using Help Command
  1. Add to your Help menu a button labeled Using Help. Also add the necessary activate callback to call your HelpRequestCB() function.
  2. Add support to your HelpRequestCB() function to display help on help. Specifically:
    • Create a quick help dialog.
    • Set the dialog's title to Help On Help.
    • Display the home topic of the help on help volume.
    • Manage the quick help dialog.
Example
The following lines create a menu button labeled Using Help... that calls the HelpRequestCB() function.
/* Create the ` Using Help ...' button. */
labelStr = XmStringCreateLtoR ("Using Help ...",           XmSTRING_DEFAULT_CHARSET);
 ac = 0;
 XtSetArg (al[ac], XmNlabelString, labelStr);     ac++;
 button = XmCreatePushButtonGadget (parent, "usingHelpButton", al,  ac);
    XtManageChild (button);
    XmStringFree (labelStr);
    /* Add a callback to the button. */
   XtAddCallback (button,XmNactivateCallback,HelpRequestCB,
    USING_HELP);
USING_HELP is the client data passed to the HelpRequestCB() function when the menu button is chosen by the user. Presumably it has been defined somewhere in the application (perhaps in a Help.h file) as a unique integer:
#define USING_HELP  47
To see how the HelpRequestCB() function handles the USING_HELP case, see the example in the next section, "To Display Help on Help."
