Copy the entire /usr/dt/dthelp/help4help/C directory to a new working directory (new-dir) using a command like this:
cp -r /usr/dt/dthelp/help4help/C new-dir
This creates new-dir and copies all the files and directories into it.
To permit editing the files (which are copied as read only), change the permissions using a command like this:
chmod -R u+w new-dir
The Help4Help volume uses these HelpTag source files:
MetaInfo
Toc
Tasks
HomeTopic
Concepts
Reference
Glossary
Also included is a control directory, where you run HelpTag to create the run-time help file. Graphics are stored in the control/graphics subdirectory.
Be sure to rename the Help4Help.htg file before running HelpTag. Your help on help volume should have a unique name to prevent conflicts with other help on help volumes.
The following commands create a copy of the help on help volume and make its files writable. (Presumably the projects subdirectory already exists.)
cp -r /usr/dt/dthelp/help4help/C /users/dex/projects/NewHelp4Help chmod -R u+w /users/dex/projects/NewHelp4Help
To build a new version of the run-time help files, first ensure that the directory /usr/dt/bin is in your search path. Then, change to the new directory, rename the Help4Help.htg file, and run HelpTag:
cd /users/dex/projects/NewHelp4Help mv Help4Help.htg NewH4H.htg dthelptag NewH4H
When the HelpTag software is done, you can display the new help on help volume using this command:
dthelpview -helpVolume NewH4H
