Common Desktop Environment: Help System Author's and Programmer's Guide
For Standalone Help
If you are writing standalone help, you are probably relying on the Helpview program already being installed and ready to use. If this is the case, you don't have to worry about help on help because Helpview accesses the standard Help4Help volume by default.
