Common Desktop Environment: Help System Author's and Programmer's Guide
Syntax
<metainfo>
<title>help volume title
The <title> element is an optional element in the <metainfo> (meta information) section. It is recommended, however, because the title provides the volume name displayed in the help dialog boxes.
The <title> follows immediately after the <metainfo> tag. Because the title of the volume may be displayed by other applications (information viewers, for example) that may not be able to format the title, you should use only plain text within the title.
The <\title> end tag is not required.
