Common Desktop Environment: Help System Author's and Programmer's Guide
Syntax
<list [bullet | order | plain] [loose | tight][continue]
[lalpha |ualpha | lroman | uroman | arabic] >
   * first item
   * second item
 <\list>
Where:
bullet
Default. Displays a bullet before each item.
order
Displays a number in front of each item. The numbers are automatically generated and begin with the number one. The default is Arabic numbers. Ordered lists can also use alphabetical sequences or Roman numerals.
plain
Does not put a bullet, number, or letter in front of each item.
continue
Requests that the numbering of items continue from the previous list.
loose
Default. Requests a vertical gap between the items.
tight
Requests no extra vertical spacing between the items.
lalpha
Lowercase alphabet.
ualpha
Uppercase alphabet.
lroman
Lowercase Roman numeral.
uroman
Uppercase Roman numeral.
arabic
Default for order list type.
Each item must start on a new line preceded by either an asterisk (*) or the <item> tag. The asterisk is the shorthand form of the <item> tag. Spaces and tabs may appear on either side of the asterisk. Items may continue over multiple lines. An item can consist of multiple paragraphs, in which case an empty line must separate the paragraphs. The nesting of lists is allowed, so a list can appear within a list.
The <\list> end tag is required.
