cmps{bwl}
compare DS:[(E)SI] with ES:[(E)DI]
Compares the byte, word, or long in DS:[(E)SI] with the byte, word, or long in ES:[(E)DI}. Before executing the cmps instruction, load the index values into the SI source- and DI destination-index registers.
cmps subtracts the operand indexed by the destination-index from the operand indexed by the source-index register.
After the data is compared, both the source- and destination-index registers are automatically incremented or decremented as determined by the value of the direction flag (DF). The index registers are incremented if DF = 0 (DF cleared by a cld instruction); they are decremented if DF = 1 (DF set by a std instruction). The increment/decrement count is 1 for a byte move, 2 for a word, and 4 for a long.
For a block compare of CX or ECX bytes, words or longs, precede a cmps instruction with a repz or repnz prefix.
Compare the 8-bit byte in the DS:[(E)SI] register to the ES:[(E)DI] register.
cmpsb
Compare the 16-bit word in the DS:[(E)SI] register to the ES:[(E)DI] register.
cmpsw
Compare the 32-bit word in the DS:[(E)SI] register to the ES:[(E)DI] register.
cmpsl
