Use pthread_mutex_init(3T) to initialize the mutex pointed at by mp to its default value (mattr is NULL), or to specify mutex attributes that have already been set with pthread_mutexattr_init(). (For Solaris threads, see "mutex_init(3T)".)
Prototype: int pthread_mutex_init(pthread_mutex_t *mp, const pthread_mutexattr_t *mattr);
#include <pthread.h> pthread_mutex_t mp = PTHREAD_MUTEX_INITIALIZER; pthread_mutexattr_t mattr; int ret; /* initialize a mutex to its default value */ ret = pthread_mutex_init(&mp, NULL); /* initialize a mutex */ ret = pthread_mutex_init(&mp, &mattr);
When the mutex is initialized, it is in an unlocked state.
The effect of mattr being NULL is the same as passing the address of a default mutex attribute object, but without the memory overhead.
Statically defined mutexes can be initialized directly to have default attributes with the macro PTHREAD_MUTEX_INITIALIZER.
A mutex lock must not be reinitialized or destroyed while other threads might be using it. Program failure will result if either action is not done correctly. If a mutex is reinitialized or destroyed, the application must be sure the mutex is not currently in use.
pthread_mutex_init() returns zero after completing successfully. Any other returned value indicates that an error occurred. When any of the following conditions occur, the function fails and returns the corresponding value.
