System Administration Guide: Basic Administration
Using Large User IDs and Group IDs
UIDs and GIDs can be assigned up to the maximum value of a signed integer, or 2147483647.
However, UIDs and GIDs over 60000 do not have full functionality and are incompatible with many Solaris features, so avoid using UIDs or GIDs over 60000.
The following table describes interoperability issues with Solaris products and previous Solaris releases.
Table 4–2 Interoperability Issues for UIDs/GIDs Over 60000
Category
Product/Command
Issues/Cautions
NFSTM Interoperability
SunOSTM 4.0 NFS software and compatible versions
NFS server and client code truncates large UIDs and GIDs to 16 bits. This can create security problems if SunOS 4.0 and compatible machines are used in an environment where large UIDs and GIDs are being used. SunOS 4.0 and compatible systems require a patch.
Name Service Interoperability
NIS name service and file-based name service
Users with UIDs above 60000 can log in or use the su command on systems running the Solaris 2.5 and compatible versions, but their UIDs and GIDs will be set to 60001 (nobody).
NIS+ name service
Users with UIDs above 60000 are denied access on systems running Solaris 2.5 and compatible versions and the NIS+ name service.
Table 4–3 Large UID/GID Limitation Summary
UID or GID
Limitations
60003 or greater
  • Users in this category logging into systems running Solaris 2.5 and compatible releases and the NIS or files name service get a UID and GID of nobody.
65535 or greater
  • Solaris 2.5 and compatible releases systems running the NFS version 2 software see UIDs in this category truncated to 16 bits, creating possible security problems.
  • Users in this category using the cpio command (using the default archive format) to copy file see an error message for each file and the UIDs and GIDs are set to nobody in the archive.
  • SPARC based systems: Users in this category running SunOS 4.0 and compatible applications see EOVERFLOW returns from some system calls, and their UIDs and GIDs are mapped to nobody.
  • IA based systems: Users in this category running SVR3-compatible applications will probably see EOVERFLOW return codes from system calls.
  • IA based systems: If users in this category attempt to create a file or directory on a mounted System V file system, the System V file system returns an EOVERFLOW error.
100000 or greater
  • The ps -l command displays a maximum five-digit UID so the printed column won't be aligned when they include a UID or GID larger than 99999.
262144 or greater
  • Users in this category using the cpio command (using -H odc format) or the pax -x cpio command to copy files see an error message returned for each file, and the UIDs and GIDs are set to nobody in the archive.
1000000 or greater
  • Users in this category using the ar command have their UIDs and GIDs set to nobody in the archive.
2097152 or greater
  • Users in this category using the tar command, the cpio -H ustar command, or the pax -x tar command have their UIDs and GIDs set to nobody.
