The following example shows the total sizes of two directories.
$ du -s /var/adm /var/spool/lp 130 /var/adm 40 /var/spool/lp |
The following example shows the sizes of two directories, all of the subdirectories and files they contain, and the total number of blocks contained in each directory.
$ du /var/adm /var/spool/lp 2 /var/adm/log 2 /var/adm/passwd 2 /var/adm/acct/fiscal 2 /var/adm/acct/nite 2 /var/adm/acct/sum 8 /var/adm/acct 2 /var/adm/sa 2 /var/adm/sm.bin 130 /var/adm 4 /var/spool/lp/admins 2 /var/spool/lp/fifos/private 2 /var/spool/lp/fifos/public 6 /var/spool/lp/fifos 2 /var/spool/lp/requests/starbug 4 /var/spool/lp/requests 2 /var/spool/lp/system 2 /var/spool/lp/tmp/starbug 2 /var/spool/lp/tmp/.net/tmp/starbug 4 /var/spool/lp/tmp/.net/tmp 2 /var/spool/lp/tmp/.net/requests/starbug 4 /var/spool/lp/tmp/.net/requests 10 /var/spool/lp/tmp/.net 14 /var/spool/lp/tmp 40 /var/spool/lp |
The following example shows directory sizes in 1024 bytes.
du -h /usr/share/audio 796K /usr/share/audio/samples/au 797K /usr/share/audio/samples 798K /usr/share/audio |
