After you successfully use NIS+ with DHCP, you might encounter errors if changes are made to NIS+ and introduce configuration problems. Use the following table to help you determine the cause of configuration problems.
Table 11–1 NIS+ Configuration Problems
Possible Problem |
Gather Information |
Solution |
Root object does not exist in the NIS+ domain. |
Enter the following command: /usr/lib/nis/nisstat This command displays statistics for the domain. If the root object does not exist, no statistics are returned. |
Set up the NIS+ domain using the System Administration Guide: Naming and Directory Services (FNS and NIS+). |
NIS+ is not used for passwd and publickey information. |
Enter the following command to view the name service switch configuration file: cat /etc/nsswitch.conf Check the passwd and publickey entries for the “nisplus” keyword. |
Refer to the System Administration Guide: Naming and Directory Services (FNS and NIS+) for information about configuring the name service switch. |
The domain name is empty. |
Enter the following command: domainname If the command lists an empty string, no domain name has been set for the domain. |
Use local files for your data store, or set up an NIS+ domain for your network. Refer to System Administration Guide: Naming and Directory Services (FNS and NIS+). |
The NIS_COLD_START file does not exist. |
Enter the following command on the server system to determine if the file exists: cat /var/nis/NIS_COLD_START |
Use local files for your data store, or create an NIS+ client. Refer to System Administration Guide: Naming and Directory Services (FNS and NIS+). |
