Task |
Description |
For Instructions, Go To ... |
Check all packets from your system |
Involves using the netstat and snoop commands and interpreting the results | |
Capture snoop results to a file |
Involves using the -o option of the snoop command | |
Check packets between server and client |
Involves saving the results of the snoop command to a file and inspecting the results |
