System Administration Guide: IP Services
How to Display Routing Table Status
The -r option of netstat displays the IP routing table.
    On the command line, type the following command.
    % netstat -r
netstat -r produces the following sample display on machine tenere:
Routing tables
Destination   Gateway Flags Refcnt Use   Interface
temp8milptp   elvis   UGH   0      0
irmcpeb1-ptp0 elvis   UGH   0      0
route93-ptp0  speed   UGH   0      0
mtvb9-ptp0    speed   UGH   0      0
mtnside       speed   UG    1      567
ray-net       speed   UG    0      0
mtnside-eng   speed   UG    0      36
mtnside-eng   speed   UG    0      558
mtnside-eng   tenere  U     33     190248  le0
The first column shows the destination network, the second the router through which packets are forwarded. The U flag indicates that the route is up. The G flag indicates that the route is to a gateway. The H flag indicates that the destination is a fully qualified host address, rather than a network.
The Refcnt column shows the number of active uses per route, and the Use column shows the number of packets sent per route. Finally, the Interface column shows the network interface that the route uses.
