Become superuser on the system where you want to enable Mobile IP.
On a command line, type the following command for each label that you want to modify in the GlobalSecurityParameters section.
# mipagentconfig change <label> <value> |
For example, if you are enabling home agent and foreign agent authentication, use the following command.
# mipagentconfig change HA-FAauth yes |
The following example shows how you might change other parameters in the configuration file's GlobalSecurityParameters section.
# mipagentconfig change MaxClockSkew 200 # mipagentconfig change MN-FAauth yes # mipagentconfig change Challenge yes # mipagentconfig change KeyDistribution files |
