Become superuser on the system where you want to enable Mobile IP.
On a command line, type the following command for each label that you want to modify in the Pool section.
# mipagentconfig change Pool Pool-identifier <label> <value> |
For example, if you are changing the base address to 192.168.1.1 and size to 100 of Pool 10, use the following commands.
# mipagentconfig change Pool 10 BaseAddress 192.168.1.1 # mipagentconfig change Pool 10 Size 100 |
