System Administration Guide: IP Services
How to Modify the SPI Section
  1. Become superuser on the system where you want to enable Mobile IP.
  2. On a command line, type the following command for each label that you want to modify in the SPI section.
    # mipagentconfig change SPI SPI-identifier <label> <value>
For example, if you are changing the key for SPI 257 to 5af2aee39ff0b332, use the following command.
# mipagentconfig change SPI 257 Key 5af2aee39ff0b332
The following example shows how to change the ReplayMethod label in the configuration file's SPI section.
Example 24–5 Changing Parameters in the SPI Section
# mipagentconfig change SPI 257 ReplayMethod timestamps
