System Administration Guide: IP Services
Monitoring IPv6
The following commands are modified to accommodate the Solaris implementation of IPv6.
You can use the new additions to conduct diagnostics. For conceptual descriptions of these commands, see IPv6 Extensions to the ifconfig Utility and IPv6 Extensions to Existing Utilities.
Monitoring IPv6 Task Map
Table 15–2 Monitoring IPv6 Task Map
Task
Description
For Instructions, Go to ...
Display interface address assignments
Displays all, or just IPv4, or just IPv6 address assignments by using ifconfig command.
How to Display Interface Address Assignments
Display network status
Displays all sockets and routing table entries. Displays inet address family for IPv4. Displays inet6 address family for IPv6. Displays statistics for IPv6 or ICMPv6 counters of interfaces by using the netstat command.
How to Display Network Status
Control the display output of IPv6 related commands
Controls the output of the ping, netstat, ifconfig, and traceroute commands. Creates a file that is named inet_type. Sets the DEFAULT_IP variable in this file.
How to Control the Display Output of IPv6 Related Commands
Monitor only IPv6 network traffic
Displays all IPv6 packets by using the snoop command.
How to Monitor Only IPv6 Network Traffic
Probe all multihomed host addresses
Checks all addresses by using the ping command.
How to Probe All Multihomed Host Addresses
Trace all routes
Uses the traceroute command.
How to Trace All Routes
You can use the ifconfig command to display all address assignments as well as just IPv4 or IPv6 address assignments.
    On the command line, type the following command.
    % ifconfig [option]
For more information on the ifconfig command, see the ifconfig(1M) man page.
Example—Displaying Addressing Information for All Interfaces
% ifconfig -a
lo0: flags=1000849 mtu 8232 index 1
        inet 120.10.0.1 netmask ff000000
le0: flags=1000843 mtu 1500 index 2
        inet 120.46.86.54 netmask ffffff00 broadcast 120.146.86.255
        ether 8:0:73:56:a8
lo0: flags=2000849 mtu 8252 index 1
        inet6 ::1/128
le0: flags=2000841 mtu 1500 index 2
        ether 8:0:20:56:a8
        inet6 fe80::a00:fe73:56a8/10
le0:1: flags=2080841 mtu 1500 index 2
        inet6 fec0::56:20ff:fe73:56a8/64
le0:2: flags=2080841 mtu 1500 index 2
        inet6 2::56:a00:fe73:56a8/64
Example—Displaying Addressing Information for All IPv4 Interfaces
% ifconfig -a4
        inet 120.46.86.54 netmask ffffff00 broadcast 120.46.86.255
        ether 8:0:20:56:a8
Example—Displaying Addressing Information for All IPv6 Interfaces
% ifconfig -a6
        inet6 ::1/128
        ether 8:0:20:56:a8
These procedures enable you to display the following structure formats for network data by using the netstat command:
    % netstat [option]
For more information on the netstat command, see the netstat(1M) man page.
Example—Displaying All Sockets and Routing Table Entries
% netstat -a
UDP: IPv4
   Local Address         Remote Address     State
      *.*                                   Unbound
      *.apexrpc                              Idle
      *.*                                   Unbound
UDP: IPv6
If
      *.*                                                           Unbound
      *.time                                                        Idle
      *.echo                                                        Idle
      *.discard                                                     Idle
      *.daytime                                                     Idle
      *.chargen                                                     Idle
TCP: IPv4
   Local Address        Remote Address    Swind Send-Q Rwind Recv-Q  State
      *.*                  *.*                0      0     0      0 IDLE
      *.apexrpc            *.*                0      0     0      0 LISTEN
      *.ftp                *.*                0      0     0      0 LISTEN
localhost.427              *.*                0      0     0      0 LISTEN
      *.telnet             *.*                0      0     0      0 LISTEN
tn.apex.COM.telnet is.Eng.apex.COM         8760      0   8760     0 ESTABLISHED
tn.apex.COM.33528 np.apex.COM.46637        8760      0   8760     0 TIME_WAIT
tn.apex.COM.33529 np.apex.COM.apexrpc      8760      0   8760     0 TIME_WAIT
TCP: IPv6
   Local Address     Remote Address   Swind Send-Q  Rwind Recv-Q   State   If
      *.shell             *.*             0      0      0      0   LISTEN
      *.smtp              *.*             0      0      0      0   LISTEN
 2::56:8.login     something.1023    8640      0   8640      0 ESTABLISHED
 fe80::a:a8.echo   fe80::a:89        8640      0   8640      0 ESTABLISHED
 fe80::a:a8.ftp    fe80::a:90        8640      0   8640      0 ESTABLISHED
Example—Displaying Inet Address Family for IPv4
% netstat -f inet
TCP: IPv4
tn.apex.COM.telnet    is.apex.COM.35388    8760      0  8760   0  ESTABLISHED
tn.apex.COM.1022      alive-v4.nfsd        8760      0  8760   0  ESTABLISHED
tn.apex.COM.1021      sl.apex.COM.nfsd     8760      0  8760   0  ESTABLISHED
tn.apex.COM.33539     np.apex.COM.apexrpc  8760      0  8760   0  TIME_WAIT
Example—Displaying Inet6 Address Family for IPv4
% netstat -f inet6
TCP: IPv6
2::56:a8.login        something.1023       8640      0  8640      0 ESTABLISHED
fe80::a0:a8.echo      fe80::a0:de.35389    8640      0  8640      0 ESTABLISHED
fe80::a0:a8.ftp-data  fe80::a0:de.35394   25920      0 25920      0 TIME_WAIT
Example—Displaying Statistics Per Interface (IPv6/ICMPv6 Counters)
% netstat -sa
RAWIP
        rawipInDatagrams    =  1407     rawipInErrors       =     0
        rawipInCksumErrs    =     0     rawipOutDatagrams   =     5
        rawipOutErrors      =     0
UDP
        udpInDatagrams      =  7900     udpInErrors         =     0
        udpOutDatagrams     =  7725     udpOutErrors        =     0
TCP     tcpRtoAlgorithm     =     4     tcpRtoMin           =   200
        tcpRtoMax           = 60000     tcpMaxConn          =    -1
IPv4    ipForwarding        =     2     ipDefaultTTL        =   255
        ipInReceives        =406345     ipInHdrErrors       =     0
        ipInAddrErrors      =     0     ipInCksumErrs       =     0
IPv6 for lo0
        ipv6Forwarding      =     2     ipv6DefaultHopLimit =     0
        ipv6InReceives      =     0     ipv6InHdrErrors     =     0
IPv6 for le0
        ipv6Forwarding      =     2     ipv6DefaultHopLimit =   255
        ipv6InReceives      =   885     ipv6InHdrErrors     =     0
IPv6    ipv6Forwarding      =     2     ipv6DefaultHopLimit =   255
ICMPv4  icmpInMsgs          =   618     icmpInErrors        =     0
        icmpInCksumErrs     =     0     icmpInUnknowns      =     0
        icmpInDestUnreachs  =     5     icmpInTimeExcds     =     0
ICMPv6 for lo0
        icmp6InMsgs         =     0     icmp6InErrors       =     0
        icmp6InDestUnreachs =     0     icmp6InAdminProhibs =     0
ICMPv6 for le0
        icmp6InMsgs         =   796     icmp6InErrors       =     0
        icmp6InTimeExcds    =     0     icmp6InParmProblems =     0
ICMPv6  icmp6InMsgs         =   796     icmp6InErrors       =     0
IGMP:
       2542 messages received
          0 messages received with too few bytes
          0 messages received with bad checksum
       2542 membership queries received
You can control the output of the netstat and ifconfig commands. Create a file that is named inet_type in the /etc/default directory. Then specify the value of the DEFAULT_IP variable. For more information about the inet_type, see the inet_type(4) man page.
  1. Create the /etc/default/inet_type file.
  2. Make one of the following entries, as needed.
    • To display IPv4 information only, type:
      DEFAULT_IP=IP_VERSION4
    • To display both IPv4 and IPv6 information, type:
      DEFAULT_IP=BOTH
      or
      DEFAULT_IP=IP_VERSION6
Note –
The -4 and -6 flags in ifconfig override the value set in the inet_type file. The -f flag in netstat also overrides the value that is set in the inet_type file.
Examples—Controlling Output to Select IPv4 and IPv6 Information
In this procedure, you use the snoop command to display all IPv6 packets.
  1. Become superuser.
  2. On the command line, type the following command.
    # snoop ip6
For more information on the snoop command, see the snoop(1M) man page.
Example—Displaying Only IPv6 Network Traffic
# snoop ip6
Using device /dev/le (promiscuous mode)
fe80::a0:a1 -> ff02::9     IPv6  S=fe80::a0:a1 D=ff02::9 LEN=892
fe80::a0:de -> fe80::a0:a8 IPv6  S=fe80::a0:de D=fe80::a0:a8 LEN=104
fe80::a0:a8 -> fe80::a0:de IPv6  S=fe80::a0:a8 D=fe80::a0:de LEN=104
fe80::a0:a8 -> fe80::a0:de IPv6  S=fe80::a0:a8 D=fe80::a0:de LEN=152
fe80::a0:de -> fe80::a0:a8 IPv6  S=fe80::a0:de D=fe80::a0:a8 LEN=72
fe80::a0:a8 -> fe80::a0:de IPv6  S=fe80::a0:a8 D=fe80::a0:de LEN=72
In this procedure, you use the ping command to check all addresses.
    % ping -a ipng11
    ipng11 (2::102:a00:fe79:19b0) is alive
    ipng11 (fec0::102:a00:fe79:19b0) is alive
    ipng11 (190.68.10.75) is alive
For more information on the ping command, see the ping(1M) man page.
In this procedure, you use the traceroute command to trace all routes.
    % traceroute -a <hostname>
For more information on the traceroute command, see the traceroute(1M) man page.
Example—Tracing All Routes
% traceroute -a ipng11
traceroute: Warning: Multiple interfaces found; using 2::56:a0:a8 @ le0:2
traceroute to ipng11 (2::102:a00:fe79:19b0),30 hops max, 60 byte packets
 1  ipng-rout86 (2::56:a00:fe1f:59a1)  35.534 ms  56.998 ms *
 2  2::255:0:c0a8:717  32.659 ms  39.444 ms *
 3  ipng61.Eng.apex.COM (2::103:a00:fe9a:ce7b)  401.518 ms  7.143 ms *
 4  ipng12-00 (2::100:a00:fe7c:cf35)  113.034 ms  7.949 ms *
 5  ipng11 (2::102:a00:fe79:19b0)  66.111 ms *  36.965 ms
traceroute: Warning: Multiple interfaces found; using fec0::56:a8 @ le0:1
traceroute to ipng11 (fec0::10:b0), 30 hops max, 60 byte packets
 1  ipng-rout86 (fec0::56:a00:fe1f:59a1) 96.342 ms  78.282 ms 88.327 ms
 2  ipng8-tun1 (fec0::25:0:0:c0a8:717)  268.614 ms  508.416 ms  438.774 ms
 3  ipng61.Eng.apex.COM (fec0::103:a00:fe9a:ce7b)  6.356 ms * 713.166 ms
 4  ipng12-00 (fec0::100:a00:fe7c:cf35)  7.409 ms * 122.094 ms
 5  ipng11 (fec0::102:a00:fe79:19b0)  10.620 ms * *
traceroute to ipng11.eng.apex.com (190.68.10.75),30 hops max,40 byte packets
 1  rmpj17c-086.Eng.apex.COM (120.46.86.1)  4.360 ms  3.452 ms  3.479 ms
 2  flrmpj17u.Eng.apex.COM (120.46.17.131)  4.062 ms  3.848 ms  3.505 ms
 3  ipng8.Eng.apex.COM (120.68.7.23)  4.773 ms *  4.294 ms
 4  ipng61.Eng.apex.COM (120.68.10.104)  5.128 ms  5.362 ms *
 5  ipng12-20.Eng.apex.COM (120.68.10.62)  7.298 ms  5.444 ms *
 6  ipng11.Eng.apex.COM (120.68.10.75)  8.053 ms  6.394 ms *
