Solaris Common Desktop Environment: User's Transition Guide
Startup and Shutdown Preferences
By default CDE saves the current session, or the details of applications running when you log out, and resumes the current session the next time you log in. You can change this and other login behavior by clicking Startup in Style Manager.
Tip -
To customize login time environment settings for the CDE login screen, modify your $HOME/.dtprofile file. (In OpenWindows, you modified your $HOME/.login file or $HOME/.profile file.)
