To install the Solaris operating environment from the network, the systems to be installed require the following servers to be present on the network.
Install server - A networked system that contains the Solaris 9 disc images from which you can install Solaris 9 software on other systems on the network. You create an install server by copying the images from the following media:
Solaris 9 DVD
Solaris 9 Software 1 of 2 CD and Solaris 9 Software 2 of 2 CD
After you copy the image from the Solaris 9 Software 1 of 2 and Solaris 9 Software 2 of 2 CDs, you can also copy the images from the Solaris 9 Installation CD and the Solaris 9 Languages CD as necessary for your installation requirements.
You can enable a single install server to provide disc images for different Solaris releases by copying the images on to the install server's hard disk.
For details about how to create an install server, refer to one of the following sections.
Boot server - A server system that provides client systems on the same network subnet with the information that they need to boot in order to install the operating environment. A boot server and install server are typically the same system. However, if the system on which the Solaris 9 software is to be installed is located in a different subnet than the install server and you are not using DHCP, a boot server is required on that subnet.
When using DHCP, you do not need to create a separate boot server. For more information, see "Using DHCP to Provide Network Installation Parameters".
For details about how to create a boot server, refer to one of the following sections:
(Optional) Name server - A system that manages a distributed network database, such as DNS, NIS, NIS+, or LDAP, that contains information about systems on the network.
For details about how to create a name server, refer to System Administration Guide: Naming and Directory Services.
The install server and name server can be the same or different systems.
Figure 10-1 illustrates the servers that are typically used for network installation.
