This example shows the contents of the mapping file that the Solaris operating environment includes for you:
# #pragma ident "@(#)050SUNWwbcou.map 1.0 01/04/03 SMI" # # Copyright (c) 2001 by Sun Microsystems, Inc. # All rights reserved. # # *** Description of contents *** # # First non-commented non-blank line contains required Version label. # Remaining non-commented non-blank lines are considered map entries # used as described below: # # Column 1 - SNMP OID - Uniquely describes an SNMP variable # Column 2 - CIM Class Name - CIM class associated with this variable # Column 3 - CIM Property Name - CIM property that maps to SNMP OID variable # Column 4 - ASN.1 type - SNMP datatype that dictates how data is mapped # to/from SNMP requests. Supported types are: SnmpString, SnmpOid, # SnmpTimeticks, SnmpCounter, SnmpInt, SnmpGauge, SnmpIpAddress, # SnmpOpaque) # Column 5 and greater are ignored # Version 1.0 1.3.6.1.2.1.1.1.0 Solaris_ComputerSystem Description SnmpString 1.3.6.1.2.1.1.3.0 Solaris_OperatingSystem LastBootUpTime SnmpTimeticks 1.3.6.1.2.1.1.4.0 Solaris_ComputerSystem PrimaryOwnerContact SnmpString 1.3.6.1.2.1.1.5.0 Solaris_ComputerSystem Name SnmpString 1.3.6.1.2.1.25.1.5.0 Solaris_OperatingSystem NumberOfUsers SnmpGauge 1.3.6.1.2.1.25.1.6.0 Solaris_OperatingSystem NumberOfProcesses SnmpGauge 1.3.6.1.2.1.25.1.7.0 Solaris_OperatingSystem MaxNumberOfProcesses SnmpGauge 1.3.6.1.2.1.25.1.2.0 Solaris_OperatingSystem LocalDateTime SnmpString |
The contents of this mapping file associate the SNMP MIB-2 System Group scalar objects with their corresponding CIM objects.
MIB-2 System Group Scalar Object |
CIM Object |
sysDescr |
Solaris_ComputerSystem.Description |
sysUpTime |
Solaris_OperatingSystem.LastBootUpTime |
sysContact |
Solaris_ComputerSystem.PrimaryOwnerContact |
sysName |
Solaris_ComputerSystem.Name |
The contents of this mapping file also associate the SNMP Host Resources MIB objects with their corresponding CIM objects.
SNMP Host Resources MIB Object |
CIM Object |
hrSystemNumUsers |
Solaris_OperatingSystem.NumberOfUsers |
hrSystemProcesses |
Solaris_OperatingSystem.NumberOfProcesses |
hrSystemMaxProcesses |
Solaris_OperatingSystem.MaxNumberOfProcesses |
hrSystemDate |
Solaris_OperatingSystem.LocalDateTime |
The syntax of the contents of a mapping file is described in Syntax of the Contents of a Mapping File.
At present, the only way to retrieve host resource data is through the CIM Object Manager, as Solaris does not currently provide an SNMP Host Resource agent.
