Common Desktop Environment: Desktop KornShell User's Guide
Fourth Area
The fourth area consists of four push button widgets, all children of the Form widget.
Graphic
The four push buttons are used as follows:
The push buttons are created and positioned in much the same manner as any of the other widgets, although they are each labeled differently. The following code segment shows how the OK push button is created:
XtCreateManagedWidget OK
ok XmPushButton $FORM \
          labelString:"Ok" \
     $(DtkshUnder $SEP3 10) \
     $(DtkshFloatLeft 4) \
     $(DtkshFloatRight 24) \
    $(DtkshAnchorBottom 10)
XtAddCallback $OK activateCallback "OkCallback"
