Common Desktop Environment: Desktop KornShell User's Guide
Set Operating Parameters
XtSetValues is used to set some initial operating parameters:
XtSetValues $FORM \
     initialFocus:$SD \
     defaultButton:$OK \
     cancelButton:$CLOSE \
     navigationType:EXCLUSIVE_TAB_GROUP
The following line configures the TextField widgets so that pressing the return key does not activate the default button within the Form. See the description of EXCLUSIVE_TAB_GROUP in Appendix B for more information on its use.
DtkshSetReturnKeyControls $SD $FNP $FORM $OK
