If
your application uses an <object-type> menu or a Selected menu, it contains
the following choices, with the specified functionality, when the actions
are actually supported by your application. Items should be presented to the
user in the order listed below.
New... [RECOMMENDED]
Creates a new instance of the object-type. A dialog box is presented
allowing the user to specify the values for settings associated with that
object. The mnemonic is N.
Move To... [OPTIONAL]
Allows the user to move the selected objects into a folder. A file selection
dialog box is displayed allowing the user to select the desired folder. The
mnemonic is M.
Copy To... [OPTIONAL]
Allows the user to copy the selected objects into a folder. A file selection
mnemonic is C.
Put in Workspace [OPTIONAL]
Allows the user to put a link for the object onto the Common Desktop
Environment desktop in the current workspace. The mnemonic is t.
Any of the preceding three menu choices should be provided
only if the objects managed by your application are able to reside as separate
entities outside of your application's main window. For example, a printer
object created by a printer management application might be able to be placed
in a Folder window and function as an application unto itself. Your application
should also support drag and drop as a method for performing any of these
actions.
Delete [OPTIONAL]
Removes the selected objects. A confirmation dialog box should be presented
to the user before the object is actually deleted. The mnemonic is D.
Properties [RECOMMENDED]
Displays a Properties window that shows the current values for settings
associated with the selected object. The mnemonic is P.
<Default Action> [RECOMMENDED]
This choice should enact the default action for the selected object.
"Open" is a typical default.
