KCMS Application Developer's Guide
KcsMeasurementBase
typedef struct KcsMeasurementBase_s {
      unsigned long                   countSupplied;
      KcsAttrSpace                    inputSpace;
      KcsAttrSpace                    outputSpace;
      unsigned long                   numInComp;
      unsigned long                   numOutComp;
      unsigned long                   pad;
 } KcsMeasurementBase;
KcsMeasurementBase defines a common subset of information in the KcsCharacterizationData and KcsCalibrationData structures. Nothing in KcsMeasurementBase is extendable.
The countSupplied field represents the number of allocated color patches, or samples in the measurement set.
The inputSpace and outputSpace fields represent the input and output color spaces, respectively, for the measurement set.
The numInComp and numOutComp fields represent the number of input components (such as 3 for RGB) and the number of output components, respectively.
