KCMS Application Developer's Guide
KcsMeasurementSample
typedef struct KcsMeasurementSample_s {
      float                        weight;
      float                        standardDeviation;
      KcsColorSample               sampleType;
      float                        input[KcsMaxSamples];
      float                        output[KcsMaxSamples];
 } KcsMeasurementSample;
KcsMeasurementSample holds a single measurement. Both the KcsCalibrationData and the KcsCharacterization data structures contain extendable arrays of KcsMeasurementSample structures. Each measurement has an input, an output, a measurement weight, standard deviation and sample type. The input and output color spaces are specified by fields in the KcsMeasurementBase structure, which is part of both the KcsCalibration and KcsCharacterization structures.
The weight field should contain a value greater than 0.0 and less than or equal to 1.0. This is to provide information about the importance of this color measurement. The KcsUpdateProfile() function may or may not use this field when performing the steps needed to update the profile. Hence, it is to be considered a hint. The default setting should be the value 1.0.
The standardDeviation field is used to record this value when the sample is the result of statistical averaging of multiple measurements.
The sampleType field is used to indicate that a sample is from a black, white, neutral, chromatic, or fluorescent color. The default value is chromatic.
To calibrate or characterize device profiles, the default KCMS CMM needs color measurements that contain both input and output values. The input and output fields hold the input and output values of a color measurement. For RGB monitors, the input values are a series of RGB values and the output values are measured luminants of the RGB value.
KcsMaxSamples equals 4, which allows up to four components of color to be stored in a measurement, for example, a CMYK color value. However, a three-component color value such as RGB or XYZ also can be stored. In such a case leave input[3] or output[3] undefined.
