IC_optspeed.scr
IC_optspeed.scr evaluates test images using complete profiles it creates with forward, reverse, and simulate transformations. It optimizes the profiles for speed and again evaluates the images.
This script demonstrates that the KCMS framework can create complete profiles with forward, reverse, and simulate transformations and can optimize them for speed. The script loads a scanner, monitor, and printer profile and creates three connected profiles with the forward, reverse, and simulate operations. It evaluates each connected profile and records the time required to perform each evaluation in the log file. Then it optimizes the connected profiles for speed and repeats evaluations. The time required to perform each evaluation is again recorded to the log file. The script does not save the color-managed images.
Each of the commands performed in this test is expected to complete successfully. The optimized profiles are expected to reduce the time required to evaluate the image.
