IC_optsize.scr
IC_optsize.scr creates complete profiles that have forward, reverse, and simulate transformations and gets the profile sizes. It optimizes the complete profiles for size. Then it gets the new profile sizes. The profiles are written to the log file.
This test script demonstrates that the KCMS framework can create complete profiles with forward, reverse, and simulate transformations and can optimize them for size. It uses scanner, color space, and printer profiles to test the OPTIMIZE: command for size. It creates complete profiles, specifying the forward, reverse, and simulate transformations. Using the GETATTR: command, it gets the size of the complete profiles. Once this is done, it uses the OPTIMIZE: command to optimize an image for size. Again the script gets the size of each of the completed profiles.
Each of the commands performed is expected to complete successfully. The optimized profile sizes are expected to be reduced from the original sizes.
