Having established the security context, gss-client
needs to wrap the data, send it, and then verify the “signature” that the server returns. Because gss-client
is an example program, it does various other things as well, such as
display information about the context, but we'll skip all of that in order to get the data sent out and verified. So first the program puts the message to be sent (such as “ls”) into a buffer:
if (use_file) { read_file(msg, &in_buf); } else { /* Wrap the message */ in_buf.value = msg; in_buf.length = strlen(msg) + 1; }
Before wrapping, the program checks to see if it can encrypt the data:
if (ret_flag & GSS_C_CONF_FLAG) { state = 1; else state = 0; }
And then it wraps it up:
maj_stat = gss_wrap(&min_stat, context, conf_req_flag, GSS_C_QOP_DEFAULT, &in_buf, &state, &out_buf); if (maj_stat != GSS_S_COMPLETE) { display_status("wrapping message", maj_stat, min_stat); (void) close(s); (void) gss_delete_sec_context(&min_stat, &context, GSS_C_NO_BUFFER); return -1; } else if (! state) { fprintf(stderr, "Warning! Message not encrypted.\n"); }
Thus the message stored in in_buf is to be sent to the server referenced by context, with confidentiality service and the default Quality of Protection (QOP) requested. (Quality of Protection indicates which algorithm to apply in transforming the data; it's a good idea for portability's sake to use the default whenever possible.) gss_wrap() wraps the message, puts the result into out_buf, and sets a flag (state) that indicates whether confidentiality was in fact applied in the wrapping.
The client sends the wrapped message to the server with its own send_token() function, which you've already seen in Establishing a Context:
send_token(s, &outbuf)
