Typedef
does not declare any data either, but serves to
define new identifiers for declaring data. The syntax is:
typedef declaration;
The new type name is actually the variable name in the declaration part
of the typedef
. The following example defines a new type called eggbox using an existing type called egg and
the symbolic constant DOZEN.
typedef egg eggbox[DOZEN];
Variables declared using the new type name have the same type as the
new type name would have in the typedef
, if it were considered
a variable. For example, the following two declarations are equivalent in
declaring the variable fresheggs:
eggbox fresheggs; egg fresheggs[DOZEN];
When a typedef
involves a struct
, enum
, or union
definition, you can use another (preferred)
syntax to define the same type. In general, a typedef
of the
following form:
typedef <<struct, union, or enum definition>> identifier;
can be converted to the alternative form by removing the typedef
part and placing the identifier after the struct
, enum
, or union
keyword instead of at the end. For example,
here are the two ways to define the type bool
typedef enum {/* using typedef */ FALSE = 0, TRUE = 1 } bool; enum bool {/* preferred alternative */ FALSE = 0, TRUE = 1 };
This syntax is preferred because you do not have to go to the end of a declaration to learn the name of the new type.
